thinking of getting the KLH receiver for a 25-31...questions
Discussion in 'Archived Threads 2001-2004' started by Keir H, Mar 8, 2002.
  1. Keir H
    Keir H Second Unit
    Jan 4, 2001
    462
    Is there anything I should be aware of by using this as a temp solution? I hear that it will shut down on TPM if played at moderate to high vol.. True? How many db's will I lose if running a 25(22)-31CS in a 3200cu/ft room? Also is there a freq limit that this amp imposes?
  2. Tom Vodhanel
    Tom Vodhanel Cinematographer
    Sep 4, 1998
    2,215
    8
    1)It will probably shut down if you run TPM at reference.
    2)you will be giving up about 4-5dB of headroom if you use the KLH instead of a S700(for example). In other words..two woofs on the KLH would be about as powerful as a single woof with the S700.
    3)not sure on the low freq extension of the KLH...never measured it.
    TV
  3. Greg Br
    Greg Br Second Unit
    Dec 13, 2001
    437
    TV
    Does the stereo shut off cause of overheating or they just getting pushed beyond their limits at any time of the movie.
