Adil M
- Nov 21, 2001
Besides being less "manageable" are there any cons to low gauge wiring. Does it affect the sound any compared to lesser gauge wiring?
This question was based on a post I read where a guy was using short 30 gauge runs to "improve/tighten" the sound.
The best system I've heard in my life used 30 or 32 gauge wire. I have no idea how it would sound with 12 gauge wire. Of course, it was a setup using 1/2W tube amps and 108dB horn speakers. Incredible dynamics, volume, control, everything. However, the crucial point there is, 1/2W and 108dB. Even with very loud music, the owner said he reckoned there was a tenth of a watt going through the wires. This is very different from your usual setup, where speakers are much less efficient and the power (i.e., current and voltage) is much higher.
It's concievable that multiple strands of copper are noisier than a single strange of copper. Also possibly less accurate in maintaining signal phase and so on. However, this noise has a relatively fixed (and low) electrical level. As long as the signal level is much higher (the "typical" setup), this noise would be practically inaudible. Once you bring the level of the electrical signal down, the noise becomes a larger percentage of the total signal content. When you use very high efficiency speakers to play this tiny signal, the noise gets amplified more than it would in a "normal" setup.
So.... I can see how it could make a difference, in theory, if you were running very low powered amps and very high efficiency speakers. However, it's speculation, and I haven't heard the same system with different speaker cables to see if I can tell a difference. Some day, I might try 22 gauge magnet wire on my 8W tube amps.
now you'd think there might be some slight roll off on the high end
How much would there be with 15' of wire? Maybe that's what "sounds better", that's a possibility too. An amp driving speakers should have an output impedance that matches the speakers, right, for maximum power transfer. I don't know the impedance of the Oris horns.
There was a theory posted a couple years back that when
listening to high volume sound (home theatre at THX levels,
voices at 85db, some sounds hitting 120db)there were very
fast, very high wattage transients happening during very
loud passages where the amplifier was being asked to
reproduce (for a very short time) wattages approaching
2000-3000 or more. I never saw any data to back this
up, but the reports some people have generated about problems with distortion have suggested that a heavy guage
cable (4-10) will help keep the distortion to a minimum.
What some people are now doing is bi-wiring using a heavy
gauge copper wire (multistranded of course) for the woofer
and a thinner guage, higher quality (silver plated copper
with teflon cladding) wire for the tweeter/midrange.
Also, people have also reported improved sound (possibly
due to reduced RFI?) when the wire going to the tweeter is twisted to produce a shielding effect. With the amount
of crap in the air from the television and digital gear,
this is not surprising.
The whole idea is to experiment to see how various
cables effect the sound, if at all. Since basic copper
speaker wire is relatively cheap, it's something you
can work at to obtain the best result.
Of course, when you get into the name branded high end
speaker cables, it ceases to be cheap to experiment!
Methinks thou hypothesises a bit too much about time smear and all that.
Quite possibly
Chris, the second wire you describe sounds like what I picked up from HD. No idea what the other one is. I vaguely remember seeing some spools of wire that looked like power supply wire - 3 solid wires of different gauges, maybe even in 12 gauge. Maybe you got something like that?
