These subs any good for HT?
Discussion in 'Archived Threads 2001-2004' started by Mark gas, Aug 9, 2002.
  1. Mark gas
    Mark gas Second Unit
    Mar 23, 2002
    322
    Are these subs any good for HT because I have heard there 12 inch sub is better than the Adire audio shriva for car use and I was wondering how they would be for ht.
    http://www.edesignaudio.com/ep/kseries.htm
  2. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    How is it better than Shiva? Shiva has much lower Fs and more excursion...DUMAX verified. Those look very cool, though, I love tha style basket...that'll sell lots to their intended market.
  3. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    Like Jack said. Looks good except for the Fs is too high and the Xmax is less (and not clear if they are mentioning Xmech or Xmax; they say Xmax, but a lot of car manufactures quote Xmech in that field).
  4. Mark gas
    Mar 23, 2002
    322
    That is Xmax not Xmech and the 15 is only $105 and it should have more displacement then the shriva for less $$.
  5. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    Your linked driver:
    Vd- 1.38L; Fs- 27hz; Cost- $105 (edit, don't know anymore)
    Dayton DVC12"
    Vd- 1.53L; Fs- 21.7hz; Cost- $105
    The Sd is actually lower than stated on PE, but the Xmax is actually higher so it evens back out to that Vd or a smidgin lower. The Fs was also DUMAXed lower than 22hz. Essentially it is a Shiva clone.
    Shiva
    Vd 1.52L; Fs 21hz; Cost- $125 including shipping
    The prices for the Dayton and Shiva are from Acoustic Visions.
    Edit, oops, just noticed you said the 15 not the 12. The 15 has a Qts that is getting a little high.
    The 15
    Vd- 2.3L; Fs- 25hz; Qts- 0.49; Cost $105
    Dayton DVC15"
    Vd- 2.44L; Fs- 20hz; Qts- 0.378; Cost $125
  6. Dan Wesnor
    Dan Wesnor Second Unit
    Apr 28, 1999
    389
    Because of cabin gain, low Fs is not as important for a car sub. An F3 in the 40's will be flat to 20Hz in most cars. Small cabinet size is more important.
  7. Jack Gilvey
    Mar 13, 1999
    4,948
    Right. That's why in general car drivers are not as good as those intended for the home...which is the application asked about.
  8. Dan Wesnor
    Apr 28, 1999
    389
    I wouldn't say not as good, but intended for different purposes.
  9. Jack Gilvey
    Mar 13, 1999
    4,948
