Joan_H
Grip
- Mar 26, 2004
Greetings:
Right now I'm using Theatertek 2.0.6 for dvd playback in my HTPC and FFDSHOW 20041012 for post-processing the image, but I have a little problem with it, after I enable FFDSHOW I can't get the original aspect ratio from any dvd. The problem begins after I enable in FFDSHOW the codec for raw video (the option I choose for it is all suported).
After I enable this codec the complete picture looks like reduced in the screen, I have to use the aspect ratio menu from theatertek to get a ratio that is close to the original but its not. I'm also using in FFDSHOW the post-processing, Blur/noise reduction and sharpen filters.
Can somebody tell me if this is a bug from FFDSHOW or this is normal and if there is a way to solve this.
Thank you.
Thank you.
