theater floor -concrete ? wood? (1 Viewer)
darron Z
the main floor of my theater should it be concrete or should i build a floor over existing slab with 2x4s and 3/4 ply - either way it will have carpet and padding. im just wondering if i want that vibration that is emitted from my subs that i currently get in my living room wood floor, i am going to install tactile transducers in the seating area anyway,but would this be too much vibes ? . the stage - should i even fill that with sand then??
Torgny Nilsson
I used to have a regular floor, and now have a concrete floor. While I love the look of the concrete floor, it does absorb much of the bass from my sub. I can still hear the sub, it no longer actually shakes the room. So, if you want your sub to shake you, you either have to build a wood floor or buy some butt kickers, which I don't care for.
AlohaTiger
