The Yamaha RX-V2400 and "presence/zone 2"
Discussion in 'AV Receivers' started by Mike~Sileck, Mar 10, 2004.
  1. Mike~Sileck
    Mike~Sileck Supporting Actor
    Feb 28, 2004
    510
    I'm looking into buying one of these and wanted to clarify somethings. I noticed it has outputs on the back for "presence/zone 2" speakers. From what I understand, this is for another room (zone) ? I also noticed it has a separate input select. So ... theoretically, if I ran speaker wire to another room, a friend could listen to 2-channel cd audio, while I'm watching a movie in the main room?
    Also, say I had these both set to the same input, I assume the presence/zone 2's would basically just be the 2 channel audio I would get if I wasnt using 5.1, and i was using 2 channel?
    Sorry if this is confusing, I'm just trying to figure this all out.
    (btw my master plan is to run a set of speakers to the bathroom for "zone 2", that way you can take a quick trip and still follow whats going on on tv or the movie, and during parties i could play ambience music in there theoretically...)
    Mike
  2. Thomas_A
    Thomas_A Second Unit
    Feb 2, 2001
    398
    the 2400 actually has 2 xtra zones....if you only use 5.1 surround. On zone 3 you can add an xtra amp for that zone. Also..you could run each zone seperatly!. all controlled form the front pannel...wich is a + over the 1400 IMO.
    I 'm using zone 2 for my patio speakers. Can watch tv in the LV room and play cd outside on the back patio! Aint America grand [​IMG]
