The ULTIMATE Toslink/S-Video switch box
Discussion in 'Archived Threads 2001-2004' started by Mike_G, Dec 18, 2001.
  1. Mike_G
    Mike_G Screenwriter
    Jun 1, 2000
    1,477
    15
    Mike
    Hi all,
    I realize that this unit was mentioned in another thread, but I love this thing SO much that I felt it deserved its own dedicated thread.
    A little background: I have a TiVo, PS2, XBox, GameCube, DVD player, and a VCR running through a Pioneer VSX-608. Because of the limited number of digital inputs on the 608, I was forced to buy a Toslink switcher from Radio Shack and still use another video switcher for the game devices. The DVD and TiVO still had their own dedicated inputs. Last night a friend of mine came over with my Christmas present. A Radio Shack Toslink/S-Video switcher with SIX inputs!!
    http://www.radioshack.com/product.as...5Fid=15%2D1987
    Its catalog ID is 15-1987.
    That's not the cool part. It converts analog audio to digital!!! My GameCube only has analog out, but while the 608 was still in digital mode, I got audio from the GameCube! It also converts composite to S-Video, has TWO OUTPUTS, and learns IR signals so that you can switch it using your remote.
    I don't normally endorse anything unless it blows me away, and this did. It's $150 and only available at the B&M store for some reason. With Cristmas a week away, this would be a perfect gift for someone that has more devices than inputs.
    Mike
  2. John Chow
    John Chow Second Unit
    Sep 18, 1998
    312
    Now all we need is something that supports component input [​IMG]
  3. Frederick
    Frederick Second Unit
    Mar 9, 1999
    400
    YES! This is EXACTLY what I've been looking for. I don't need component since my tv isn't HD, and all of my other systems are S-Video going into a switcher now. Thanx, Mike!
    Freddy C.
  4. Mike_G
    Mike_G Screenwriter
    Jun 1, 2000
    1,477
    15
    Mike
    There are 3 RCA inputs on it (Composite video, left and right audio). This SHOULD work if you plug in the 3 component jacks there. I don't know if there will be any issues plugging in a component plug into the composite jack since the unit does composite->S-Video conversion, but I'll bet it's worth a try.
    Mike
  5. Brett_V
    Brett_V Extra
    May 9, 2001
    20
    I seriously doubt that you could use this device to switch component signals instead of the intended composite signals it was designed for. You wont do any harm, but dont spend $150 hoping that this might be the case.
  6. Jeff D
    Jeff D Supporting Actor
    Apr 6, 1999
    604
    Mike G, the connectors are the same, the specs on the signals.... that's a different story.
    It might work, but chances are there would be signal degradation. Which would result in poor video.
    Anyone try this? I'd like to see measurements on the outputs. =)
  7. DaViD Boulet
    DaViD Boulet Lead Actor
    Feb 24, 1999
    8,800
    3
    will it pass digital signals like DD or DTS without currupting data? Has anyone used it to switch DD sound between a DVD player and a DSS receiver, for instance?
    -dave
  8. Dave F
    Dave F Cinematographer
    May 15, 1999
    2,885
    2
    Regarding using a composite switchbox for component switching, check this thread: http://www.hometheaterforum.com/htfo...threadid=13940
    The composite switchbox performed very well in the tests. (I haven't tried it yet, as I have no need for another component input at this time).
    -Dave
