The two versions of CE3K
Discussion in 'DVD' started by paul:hillsdon, Mar 20, 2004.
  1. paul:hillsdon
    paul:hillsdon Stunt Coordinator
    Jan 11, 2004
    75
    When I was looking for Close Encounters of the Third Kind on DVD, I saw that there are 2 versions of the Collector's Edition. 1 released in 2001, and 1 in 2003. Is one different than the other? Is the new version simply a repackaged 2001 release? Which should I get?
    Thanks in advance!
  2. David_Blackwell
    David_Blackwell Screenwriter
    Jan 30, 2004
    1,435
    Just looked over at Amazon.
    The 2001 version has all the extras and is a 2 disc release where the 2002 one is one disc with no extras (even though the 2002 one has DTS).
    I should buy the 2 disc version one of these days.
    Be Seeing You,
    David Blackwell
  3. Jake Johnson
    Jake Johnson Second Unit
    Apr 25, 2003
    367
    Buy the 2 disc release. The one WITHOUT the kid on the cover. It has DTS, and some serious rock n' roll martian extras.
  4. WillG
    WillG Producer
    Jan 30, 2003
    5,726
    179
    Definately get the two disc version. It is known as "The Collector's Edition" It has DTS and the second disc has an approx 1:45 documentary on it which is very valuable, deleted scenes, including the "Inside the Spaceship" scene, a short featurette, trailers and some cast/crew info.
    The single disc edition is just disc one.
  5. AlexBC
    AlexBC Second Unit
    May 1, 2003
    259
    The Japanese Superbit offers much better PQ and the fine DTS track. The movie is splitt across 2 discs to keep the higher average bitrate. Though it looses all the extras.
  6. Bill J
    Bill J Producer
    Oct 27, 2001
    3,970
    Isn't the 2-disc version OOP?
  7. paul:hillsdon
    Jan 11, 2004
    75
    Thanks all,
    and Bill J: It's still for sale at Amazon!
  8. Joel Fontenot
    Joel Fontenot Supporting Actor
    Aug 9, 1999
    910
    175
    Baton Rouge, LA
    Joel Fontenot
    OOP doesn't mean "out of stock". Only that it will be out of stock some day...soon [​IMG].
  9. WillG
    WillG Producer
    Jan 30, 2003
    5,726
    179
    Pick it up while you can. If you are a fan of CE3K, you will regret not being able to get the 2-Disc version should it not be available anymore
