ChadMcCallum
- Sep 8, 2002
I don't have a a surround sound system but I'm interested in this one http://www.futureshop.ca/catalog/pro...id=10#MoreInfo
Surround yourself in sound with Sony's STR-DE697 Dolby Digital Receiver. This full-featured model has all of the functionality you'll need to get the most out of your home theatre. With 7.1 channel power, built-in Dolby Digital and DTS decoders, you can enjoy the awesome sound of DVD or digital satellite systems.
4 Ohm Capable No
5 Channel Power Yes
5.1 Channel Discrete Input Yes
6 Ohm Capable Yes
6.1 Channel Discrete Input No
7.1 Channel Discrete Input No
A/V Inputs/Outputs 4 Inputs, 1 Output
Banana Plug Speaker Terminals Info Not Available
Component Video Input/Output Yes
Component Video Switching Yes
Composite Video Input/Output Yes
Digital Inputs 4
Digital Outputs 1 Optical
Dolby Digital EX Yes
Dolby Digital Surround Sound Yes
Dolby Pro Logic Yes
Dolby Pro Logic II Yes
DSP Modes 13
DTS Yes
DTS ES Yes
Front AV Jacks Yes
Graphic EQ No
Headphone Jack Yes
High Current No
Included In Box Remote, Batteries, Manual, Antenna
Multiroom Capability No
On Screen Display Info Not Available
Phono Inputs No
Preamp Outputs No
Product Dimensions 43.0(W) x 15.7(H) x 31.0(D) cm
Product Warranty 2 Year Parts & Labour
Product Weight 8.5 kg
Remote Control Type Programmable
S-Video Input/Output 1
S-Video Switching Info Not Available
Station Presets 30
Stereo Power Per Channel 110 Watts Per Channel
THX Select No
THX Ultra No
More Information
FEATURES:
7 Channel Power Rating: 100 Watts Per Channel x 7
32-bit Dolby Digital, Dolby Pro Logic and DTS Decoder.
32-bit DSP with 11 acoustic environments.
Digital Cinema Sound System with Cinema Studio EX modes.
Is this a good reciever? Will I be able to connect my PS2 to it? It says it supports 7.1 but it doesn't have 6.1 and 7.1 discrete inputs. Can someone explain this to me? Thanks.
4 Ohm Capable No
5 Channel Power Yes
6 Ohm Capable Yes
Digital Inputs 4
Dolby Pro Logic Yes
DSP Modes 13
DTS Yes
DTS ES Yes
Front AV Jacks Yes
Graphic EQ No
Headphone Jack Yes
High Current No
Phono Inputs No
Preamp Outputs No
Station Presets 30
THX Select No
THX Ultra No
More Information
FEATURES:
