The Ring DVD- Whats the difference between these two versions?
Discussion in 'Archived Threads 2001-2004' started by Chris_House, Oct 5, 2002.
  1. Chris_House
    Chris_House Agent
    Jul 26, 2001
    46
  2. Jeff Kleist
    Dec 4, 1999
    11,267
    It's the same disc, both PAL
    One thing I have noticed is all the people calling it "Ringu". In Japan they use an alphabet called katakana to write foreign words which APPROXIMATES the proper way to say it. So it's always "The Ring"
  3. JonS
    JonS Stunt Coordinator
    Jun 24, 1999
    94
    Neither are correct. There is no official version that I know of that is Region 0.
  4. Greg_D_R
    Greg_D_R Stunt Coordinator
    Mar 11, 2001
    221
    4
    Actually, the Tartan release (the first link) is indeed a legitimate Region 0 release. Most if not all Tartan releases are R0. I'm not sure about the other one.
    The Tartan release is generally considered to be the best version with English subs so far.
    This probably should be in the Regional DVD section.
  5. Jeff Adkins
    Jeff Adkins Screenwriter
    Sep 18, 1998
    1,775
    22
    1,610
    Jeff Adkins
  6. Sean Patrick
    Sean Patrick Supporting Actor
    Apr 22, 1999
    732
    is the transfer on the Tartan dvd decent? is it really anamorphic?
  7. cafink
    cafink Producer
    Apr 19, 1999
    3,043
    37
    Carl Fink
    Is there an NTSC DVD of this film with English subtitles? I'm multi-region capable, so that's not a problem.
  8. Chris_House
    Chris_House Agent
    Jul 26, 2001
    46
    Jeff Kleist,
    When you say they are the same discs, do you mean they are both the Tartan release, just with a different cover?
  9. Jeff Kleist
    Dec 4, 1999
    11,267
  10. Rolando
    Rolando Screenwriter
    Feb 19, 2001
    1,326
    4
    110
    So what is the absolute best DVD release of this movie and best place to get it? I am in Montreal, Canada and have region free player that can do PAL to NTSC.
  11. Jeff Kleist
    Dec 4, 1999
    11,267
    If you have an HTPC, or are fluent in Japanese. The Japanese disc is the best
    If you have neither of the above, get the Tartan
  12. Chris_House
    Chris_House Agent
    Jul 26, 2001
    46
  13. Greg_D_R
    Mar 11, 2001
    221
    4
  14. Chris_House
    Chris_House Agent
    Jul 26, 2001
    46
    Greg_D_R,
    On that link, it says it is region 2.
  15. Chris Xolotl
    Chris Xolotl Second Unit
    Jun 28, 2001
    482
    FINE FINE FINE! OK. The CD-Wow version is the Australian PAL version distributed by AV Channel.
    It is legit and came out recently. I haven't seen any reviews of it though. It Region 1,2,3,4,5,6 (not R0) but close enough. 91 Minutes. Anamorphic and Stereo.
    With English Subs there are only two legit PAL DVDs and no legit NTSC DVDs (i.e. those pesky E-Bay Bootlegs).
    The Tartan PAL R0 leave A LOT to be desired. Maybe I'll pick up the OZ disc just to check.
  16. Chris_House
    Chris_House Agent
    Jul 26, 2001
    46
    So what is the difference between region 0, and region 1,2,3,4,5,6?
  17. Jeff Kleist
    Dec 4, 1999
    11,267
    Region 0 is also known as "All Region" or "region free"
    You can play it anywhere
  18. Jeff Adkins
    Sep 18, 1998
    1,775
    22
    1,610
    Jeff Adkins
  19. Chris Xolotl
    Jun 28, 2001
    482
    But, why would you want a bootleg?
    Anyways, about all regions etc.. The Ring won't play in
    Region 07 (Reserved)
    Region 08 (Int'l Venues, Airplanes, Cruise Ships)
    But will play everywhere else that is PAL compatible.
  20. Rolando
    Feb 19, 2001
    1,326
    4
    110
    so is the Tartan release the one to get or this "CD WOW/Australian" release mentioned above...
    sorry to repeat myself but want to make the right purchase the first time.
