The Prince of Egypt: DD or DTS??
Discussion in 'Archived Threads 2001-2004' started by JoshB, Mar 7, 2003.
  1. JoshB
    JoshB Supporting Actor
    Dec 25, 2001
    901
    Joshua Bal
    I am considering purchasing this, but I am curious as to the differences in the audio tracks. I know the extras are the same, as well as the transfers, the only difference between the two is the DTS track, which is full bit-rate. Is the DTS better? I have heard some say it is and it isn't. Some say the DTs is better, but that the effects drown out the music (Hans Zimmer's score, not the songs). So I am just wondering whic his the better of the two.
  2. BrianP
    BrianP Supporting Actor
    Dec 8, 1999
    601
    I owned both and thought the DTS version did sound better, but Dolby Digital was also very good.
  3. Brendon
    Brendon Second Unit
    Jun 15, 1999
    257
    Josh,
    I replaced my DD version of POE with the DTS version some time ago. The difference is clearly audible to me. Should you get chance to do a comparison, I feel the difference is apparent from the start: The sounds of the wind gusting around the room with the cornet starting the main theme of "Deliver Us" hangs between the speakers, rather than sounding tied to each of them as per the DD 5.1 track.
    DVDfile's review of the film gives a good, articulately written comparison of the two soundtracks. (Much better than my clumsy attempt at explaining anyway!)
    Brendon
  4. Todd Phillips
    Todd Phillips Second Unit
    Oct 15, 2000
    279
    I was the one who said that I prefered the DD version, but as it is, I have both versions and I can't get myself to get rid of either.
    I had the DD first and got used to it, and, like I said elsewhere, I feel the DTS version pushes the score more to the background (relative to the other sounds). But the DTS does give a more tactile feel to the sound effects, and the music seems to have a higher frequency range.
    So get the DTS version, and you'll probably be happy (everyone else seems to be).
  5. kevin_asai
    kevin_asai Stunt Coordinator
    Mar 12, 2001
    218
    There is a new version of Prince of Egypt. It features both dts and dolby digital. Someone in this forum pointed saw it. I've seen it too in local stores.
    FYI, Chicken Run has a new version too. Lesser extras and no dts [​IMG]
  6. Arif
    Arif Agent
    Nov 20, 2002
    27
