Jeffrey_S
- Jan 17, 2002
OK,
Like I have posted in other threads, I have my Tempest drivers (two of them) and although I thought I was building a dual Tempest sonosub, I might have to go with twin conventional Adire Alignment vented subs due to SAF. I will know by the end of the week which way this will go. If I do have to go with two subs instead of one with two drivers, I was wondering about placement. They are probably going to be too large and heavy to stack at about 38" tall. Would side by side placement work? I guess I have two questions.
1. Do I have to worry about wave cancellation with side by side placement, or should I really find a way to stack these? If I did stack them, I guess I could go with one firing down and one firing up. Would this work with separate plate amps in each?
2. Will two AVA250 plate amps be adequet to drive these? Is there any downside in using the PE equivalent plate amp? I'm confused as to whether or not that one has a rumble filter. Do I really need a rumble filter?
As always, thanks to everyone for your help!
Jeff
Jeff
