The old speaker-in-the-column trick...
Discussion in 'Home Theater Projects' started by Dave Poehlman, May 4, 2005.
  1. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    3,813
    For those of you who've built grill cloth sections to your columns to hide your speakers:
    How did you attach the grill cloth and allow future access to the speakers?
    I mean, framing it seems simple enough.. but making it removable might be a problem.
    If anyone wants to see an example of what I'm talking about: Click Here.
  2. Michael Whitney
    Michael Whitney Stunt Coordinator
    Feb 17, 2005
    50
    Not having done it, but I could imagine stretching the grill cloth over a cutout U shaped frame and sliding it in between the upper and lower trim pieces. I could picture velcro holding the frame to the wall/column at the tips of the u shape for permenance and strength.
    Another could be stretching the cloth over the open face frame with flap sides and velcro attaching the flap sides to the sides of the column.
    I hope this helps, dont know if I made any sense.
  3. SteveLeach
    SteveLeach Stunt Coordinator
    Nov 19, 2003
    159
  4. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    Rather then those ball and socket connector use neodymium magnets instead. they're cheap and hold grills on very well.
  5. Dave Poehlman
    Mar 8, 2000
    3,813
    [​IMG]
    Here is a rough idea of what it might look like. It's an "open concept" layout, obviously (for WAF reasons) with sort of a bar/counter acting as the rear seating. The rearmost surround speakers would be mounted on the back wall (not pictured).
    I don't know if I'd be able to pull off the columnar idea with the full column (which also contains a support pole).
