Paul D G
- Dec 25, 2001
Hey all -
I'm a bit baffled by something, and you lot are a knowledgeable group so I put the question to you. Maybe someone has some thoughts.
To avoid an unnecessary wall of text, here are some factoids:
- Around Nov 15th I pulled the snow blower out of storage.
- It already had some gas (50:1 mix) in it, with fuel stabilizer.
- I was having trouble getting it started (as always, damn thing) so I poured in the rest of the 50:1 mix I had in a storage tank. Not a lot, but I figured a little fresher fuel would help.
- I got it started, and put it in the garage, ready for snow.
- No snow fell.
- We're about to get a storm here, 2 months later, so I thought I should fire up the blower because it's always easier to start after short periods of time.
- I could not get it started.
- I opened the tank and gave it a shake and heard no fuel sloshing around. I shook it vigorously.
- Hmmm.
- I took some paper towel and twisted it to a stiff probe and stuck it in the tank. It came out dry.
- Hmmm.
- I created a new gallon of 50:1 mix and poured a little in the tank. Juuuuust enough.
- Started right up.
It seems the gas in the tank from Nov disappeared, which seems really odd. The blower has a little edge inside the tank so you can't see the gas level apart from a little sliver on the side. There was a good amount of gas in the tank then, enough to be visible, and I still added more.
What's odd is the garage had a heavy smell of gas for a good week or two after I started it that first time. I wouldn't say it's unusual to smell a little gas because of the exhaust and the choke lever usual has some smelly residue, but for so long was a little strange. There is no stain under where it sat so it's not like it was dripping out. There is no smell of gas currently after starting it up.
Any thoughts on what happened here?
No, I don't think anyone stole it somehow. I keep two 2 gallon containers of gas just inside the garage door. If anyone wanted to steal gas they could have just grabbed those containers.
- No snow fell.
- Hmmm.
- Hmmm.
- Started right up.
