SJeans123
- May 14, 2024
- Sam Jeans
When shopping for speakers, you’ll certainly encounter a huge range of technical specifications.
Frequency response, sensitivity, impedance, and so on, go a long way to explain how a speaker will sound, how much power it requires, and how well it’ll work with your other audio components.
However, making sense of them all together is tricky. Some mean more than others. Some are a need-to-know. Others are more marketing-speak.
Here, we’ve broken down all the key loudspeaker specifications anyone needs to know, explaining what they mean and how they relate to your listening experience.
By the end, you’ll have a clearer understanding of how to use specs to choose the right system.
Frequency Response
First up, frequency response. This tells you the range of frequencies a speaker can reproduce, from the lowest bass notes to the highest treble tones.
It’s expressed as a range extending from 20Hz to 20kHz (it may extend further, but this is the important bit of the range), representing the limits of human hearing. We can generally perceive sounds from about 20 Hz (very low bass) up to around 20,000 Hz (very high treble).
However, it’s important to note that our sensitivity to frequencies varies. We’re most sensitive to sounds in the midrange (around 1kHz-5kHz), which is where vocals and most instruments reside. Our perception of bass and treble frequencies is less acute, especially at the extremes of the audible spectrum.
So, while a speaker with a frequency response of 20Hz to 20kHz can theoretically reproduce the entire range of human hearing, the audibility and impact of frequencies at the edges of this range will be less pronounced.
Continue reading...
