Adam Smith
- May 27, 2003
So I could just be slow in the head, but it took a bit of effort to get my HTPC to output 720p over DVI. I'm hoping to clear any confusion there might be about whether or not it's possible (it most definitely is). Sorry about the image width.
Prerequisites:
1. NVIDIA or ATI card with DVI out
2. M1-DVI cable (I have the 10m)
3. The latest (or at least close) video drivers
When properly set up, the computer will detect your display device as an Infocus SP4805-D (and not Plug N Play Monitor or any of that business). It should do this as soon as you get everything physically connected and powered on. Then, you'll need to enable one of two settings, depending on who makes your video card. They're both somewhat hidden and hard to find unless you know what you're looking for.
1. Right click an empty area of your desktop and click "Properties".
2. Click the "Settings" tab.
3. Click "Advanced".
NVIDIA cards:
4. Click the tab with the NVIDIA icon and the name of your video card.
5. Click "nView Display Settings".
6. Right click the picture of the monitor.
7. Click "Treat Digital Display as HDTV".
8. Under "Select TV format" directly under, select the resolution you wish to run (I run 720p).
ATI cards:
4. Click the "Displays" tab with the ATi icon.
5. Click the heading that says "FPD".
6. Select "Force 720p mode".
Note: You may have to fiddle with changing the resolution beforehand for this to work. The resolution should change as soon as you click OK to everything. I don't know why it doesn't work once in a while.. probably yet another bug in ATI's drivers.
I hope this helps somebody.
Prerequisites:
NVIDIA cards:
ATI cards:
