Chuck Bogie
- Jan 14, 2003
Okay - My brother in law was cleaning out his basement, and I received a couple of pairs of pretty old speaks... One (2-way sealed box from EPI? heavy little buggers...) wasn't all that bad, and is over in a friend's basement, and I kept the big boxes, labeled Altec Lansing something something...
These things are odd... I thought it was a weird 2-way sealed design, but when I pulled the drivers, it turned out to be a 10" woof and a 10" passive radiator. The thing also has a pair of cone tweeters.
The radiators are pretty ate up, the woofs not quite as bad - but I doubt they'd be worth messing with unless these were just incredible speakers (the guy said he's spent a bunch on 'em...), which I somehow sorta doubt...
The wires come from the back directly (do not pass go, do not collect $200) to the woof, then on to the tweets (8 mike cap and something I didn't recognize) via an L-pad. The tweets are paralleled.
The box is just a hair under two cubic feet.
Well, here's what I'm thinking... A pair of the 10" dayton woofs (I think they're $22 or something like that...) and a silkie and plug the other hole. Or should I run two silkies? The holes are 3" so I'm not gonna have to play with the router... Gonna stuff it pretty heavy. Other alternative would be one silkie and a vent, but it'd be WAY undersize, so I'm guessing it'd need a LOT of stuffing...
Cross 'em at approx. 1850ish? What sort of weirdness am I going to run into running the multiple speakers?
These are going to be basically party speakers to keep in the back of my van...
