The Ceiling Fan Must Go!
Discussion in 'Home Theater Projects' started by Colton, Apr 5, 2005.
  1. Colton
    Colton Supporting Actor
    Jan 12, 2004
    795
    Hi, guys ...
    Anyone have any suggestions on what I should replace a ceiling fan with in a dedicated HT? The ceiling fan is in the direct path between the projector and screen, so it needs to be pulled down. Would love to hear suggestions on what I could replace it with. A flush dome light?
    - Colton
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,099
    33
    Katy, TX
    Wayne
    ?? Those don’t cool you off very well...
  3. Doug_H
    Doug_H Supporting Actor
    Mar 21, 2000
    586
    I just replaced mine with a dome style light from Home Depot. You shouldn't need to go with a flush mount light unless it is right at the projector.
    I added an Smart Home dimmer switch and it helps ad to the mood of the theater.
  4. Tony Loewen
    Tony Loewen Stunt Coordinator
    Nov 21, 2003
    134
    why do you have to replace it with anything? I took out a ceiling fan that was inbetween my projector and screen, and used the octogon box as a JB for a couple of recessed lights I put in on either side of where the fan was. Are you asking because the room/ceiling is finished and you don't want a big gaping hole in it? I believe you can get decorative blanking plates that would look alright. If you don't need anything there, just disconnect the wires, stick a couple of marrettes on the ends, and seal it up. (well, not sealed up I guess, you still need access to it if there are other connections in there, code rule, in Manitoba anyway)
  5. Colton
    Jan 12, 2004
    795
    Well, I don't want to have to take it down, but this one has four glass lamps that hang from the base.
    Kinda like these:
    http://images.overstock.com/f/102/31...ts/L916256.jpg
    Maybe I could substitute it with a flush ceiling fan that has a light dome base. I'm just afraid that a ceiling fan with disrupt the projection. Anyone have experience with this?
    - Colton
  6. todbnla
    todbnla Screenwriter
    Oct 17, 1999
    1,514
    39466
    Todd
    My ht is about 95% complete and in our room we have 2ea 52" flush mt fans, picked them up @ Lowes, don't need lights, have 4 recessed cans, don't see any problems with p/j viewing in my test run, made sure the fans themselves would not reflect (flat black) as We need the fans, it gets very hot/humid down here.
  7. Jason-Mar
    Jason-Mar Auditioning
    Apr 5, 2005
    11
    On most fans you can remove the "light kit" and install a blank plate where the lights attached. This might give you enough room... Check it out.
