DougLainson
- Dec 2, 2001
First all, I want to say a great thanks to the owners and moderators of this forum. It's a total class act and I have already gained invaluable information as I attempt to educate myself on Home Theater basics.
Finally, after 13 years of marriage and 3 kids, my wife has given me permission to invest some dollars into a new home theater set-up (She still thinks the 27" TV and stereo speakers are ok--and that I have a disease). I would like to know if I can salvage any pieces from my stereo set-up or if I should just start over. Primarily, should I look at using my Advent Prodigy towers and add a center channel, surrounds and sub, or are the Advents so bad that I should scrap them...(I think they still sound great, but I might be whacked and they might not mix well...)
Decisions I have made so far:
Monitor--> Pan 36 HX41 (sharper than xbr 450 with analog source and dealer told me they would stand behind it should I get one with the geometry problems--which are getting better. Apparently Panasonic is fixing QA process) I love the XBR 700 but it won't fit into the cabinet my wife picked...(you win some you lose some)
Recver--> Deciding between Onkyo 696, Denon 2802, and Yahmaha RX1000--should I add another for consideration? (currently leaning to the Onkyo. They all seem pretty good, but I like the Onkyo zone 2 feature.)
Speakers--> Adding a JBL S-center, N24 surrounds and PB12. Will this work with the Advents? I'm I being cheap? Should I just get new S38 for the fronts? Should I consider something else all together? The JBL sounded good, but so did the Energy's XL series. But I really liked the JBL center.
DVD--> New JVC XA-FA90. Progressive output 7 disc changer.
Looks good on paper--any one got experience?
Bottom line: I just want to know if I am going the in the right direction and will be happy with this potential set-up or if I'm way off base. Comments and criticism welcome. Thanks
