Testing Airt tightness of a sub
Discussion in 'Archived Threads 2001-2004' started by SteveF, Mar 24, 2002.
  1. SteveF
    SteveF Extra
    Jun 5, 2000
    24
    Any tips for testing that a sealed subwoofer is
    airtight?
  2. Ryan T
    Ryan T Second Unit
    Sep 10, 2001
    406
    I have the exact same question. I read somewhere that you should run a 10 Hz test tone at moderate levels. Then move your fingers along all the eges to feal for any air moving out. I did this but I don't know how well it really works.
    Ryan
  3. Pete Mazz
    Pete Mazz Supporting Actor
    May 17, 2000
    761
    One I read was to hold the edge of a tissue and move it along the seams.
    Pete
  4. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    Probably NOT a good idea to use 10Hz test tones unless the woofer is VERY stout one. Try 30-40Hz instead.
  5. Rudy H
    Rudy H Stunt Coordinator
    Mar 2, 2002
    105
    Push the cone in and see if you can hear any hissing.
    A 2-5hz tone will do the same thing though... just be careful when you do it [​IMG]
