Terminator 2 UE Audio Dropout
Discussion in 'Archived Threads 2001-2004' started by Stan T, Feb 8, 2002.
  1. Stan T
    Stan T Stunt Coordinator
    Mar 2, 2001
    217
    I was watching Terminator 2 UE on my Pioneer Elite DV-38A & experienced several audio dropouts. I was watching the DTS track. It happened around 6 times throughout the movie & only lasted for a split second. I didn't try the Dolby Digital track.
    I tried to do a search to see if there was any problems with this disc but wasn't able to find anything. Has anyone else experienced this problem with this disc? Thanks for the replies.
  2. Adam Barratt
    Adam Barratt Cinematographer
    Oct 16, 1998
    2,343
    Adam
    There were numerous reports of DTS dropouts when this disc came out, so it's a fairly well-known problem. It's possible that your player was having problems with the disc's seamless branching: this is a likely cause if the dropouts were repeatable at specific points during the film.
    Adam
  3. Dharmesh C
    Dharmesh C Supporting Actor
    Jul 25, 2000
    994
    [​IMG] I get the dropouts, too. I've only ever tried DTS, but it does happen during the Seamless branching sequence.
    My player is a Tosh 100SD
  4. Jeff
    Jeff Supporting Actor
    Jun 30, 1997
    947
    No dropouts playing the SE version (seemless branching) with DTS on my Panasonic RV-80. I used to have a Pioneer DV-09 and had no dropouts on that either.
    Jeff
  5. Garry I
    Garry I Stunt Coordinator
    Feb 9, 2001
    58
    I have a pioneer dvd player and i have noticed dropouts on the DTS track at 2 points. At these 2 points, they weren't detected with the Dolby track. Apparently to do with seamless branching.
  6. Scott Merryfield
    Dec 16, 1998
    12,735
    1,337
    9,110
    I had the same problem at the seemless branching points using my old Toshiba SD-6200 player. My current Panasonic RP-91 plays this disc fine.
  7. Stan T
    Mar 2, 2001
    217
    Then I don't have a defective disc? The dropouts occur while watching the SE version with the DTS track. Like I said I haven't tried the Dolby Digital track to see if the dropouts occur on that track also. For those of you that have the DTS dropouts do you have dropouts on the Dolby Digital track also? Is the seamless branching causing the audio dropouts if I'm watching the Special Edition version?
    This is the first problem disc that I have ever had. Even Disney's "Dinosaur" played fine. Thank goodness the dropouts only last for a brief second. It just sounds like a quick glitch.
  8. Scott Merryfield
    Dec 16, 1998
    12,735
    1,337
    9,110
    The "SE" version is the seemless branching version that places additional scenes in the film using DVD's seemless branching feature. As for whether this occurs on the Dolby Digital soundtrack, I could not tell you. I only listened to the DTS soundtrack on my old Toshiba player.
