Terminator 2 packaging question
Discussion in 'Archived Threads 2001-2004' started by JJR512, Oct 17, 2001.
  1. JJR512
    JJR512 Supporting Actor
    Dec 11, 1999
    619
    Already owning a copy of the originally-released T2 on DVD, I was initially reluctant to get the new Ultimate T2 in the metal slipcase when it came out. I finally decided to get it recently, but had a hard time finding it. I finally thought I found it yesterday at Best Buy, but it wasn't really a metal slipcase...it was a metal-colored cardboard slipcase. Aside from that, I understand the contents are the same. Even better, despite being marked at $34.99 it scanned at the register for only $19.99.
    But I really want the metal packaging. Obviously, if there is any "collectible value", it will be with that. Has it been discontinued? Will I not be able to find it anywhere, should I just give up and keep the cardboard version, or is there any hope of finding the metal version again? If so, I'll return the cardboard version.
    -Justin "JJR512" Rebbert
    [​IMG]
    Join our [email protected] Team! (Click here for more info.)
    Contact me: [email protected] | ICQ: 52675695 | Private Message
  2. PhilipW
    PhilipW Second Unit
    Mar 5, 2001
    268
    Do you have a Sam's Wholesale near you. I've seen them there for $17.99
  3. Tom Morgan
    Tom Morgan Stunt Coordinator
    Aug 1, 1999
    119
    The Sam's Club here had a bunch with the metal case for ~$20 yesterday.
    [​IMG]
    Tom&Amy's DVD's
  4. JJR512
    Dec 11, 1999
    619
    Is that the same as Sam's Club, sister-store to Wal*Mart?
    [​IMG]
  5. PhilipW
    PhilipW Second Unit
    Mar 5, 2001
    268
    Yep one and the same
  6. JJR512
    Dec 11, 1999
    619
    I know where one is, about a half-hour away from me. I've never been there, though. Aren't they a membership club? How much does it cost to join?
    [​IMG]
  7. JasonKrol
    JasonKrol Supporting Actor
    Aug 19, 2001
    505
    i believe that I read somewhere in this forum that they stopped producing the metal versions of the disks.
    im assumming that if thats true, the ones your all talking about are leftovers etc.
    good luck finding one though!!
    - Jason
    My DVD Collection | My Home Theater
    "what ya got here is two people dragging a third..."
  8. Dean DeMass
    Dean DeMass Screenwriter
    Jun 30, 1997
    1,826
    Justin,
    YGM!
    -Dean-
    My HT Equipment
    "I've seen you and you are not cool."
  9. Rob T
    Rob T Screenwriter
    Aug 26, 2001
    1,987
    I got mine at Wal-mart. [​IMG]
  10. JJR512
    Dec 11, 1999
    619
    Today I looked in two Sam's Clubs, one big Wal*Mart, one Best Buy (knowing another didn't have it), and Suncoast Video. Nobody had it. The guy at Suncoast said that the metal-sleeve version had been out of print for a while, that it had been replaced with the current metal-colored cardboard sleeve version, and that the metal-sleeve version could not even be special-ordered anymore. He said the only difference, aside from the sleeve, was that the metal-sleeve version was on one disc, whereas the newer metal-colored cardboard sleeve version is on two discs.
    [​IMG]
  11. cafink
    cafink Producer
    Apr 19, 1999
    3,043
    37
    Carl Fink
    The original Metal-case release of T2 was actually available in two forms. One came on a DVD-18 (that's a double sided disc), in normal keepcase, inside a metal slipcase. The second version was essentially the same, but contained two DVD-9s (single sided discs). This version was in the thin Amaray double-disc case, and was almost indistinguishable from the DVD-18 version (the only difference was a small note on the package).
    The new cardboard-case version is essentially the same as the previous double disc version, but now comes in the fat alpha double case, silver colored.
  12. Mark Zimmer
    Mark Zimmer Producer
    Jun 30, 1997
    4,300
    40
    I just saw a metal-cased T2 (didn't note if it was 1 or 2 disc version) at Borders; they often pull old stock out of the warehouse and thus have it available when no one else does (such as with the Universal-Image discs that were still at Borders long after going OOP).
    "This movie has warped my fragile little mind."
  13. DannyS
    DannyS Second Unit
    Jul 9, 2001
    328
    it the 2 disc one considered rare?
  14. cafink
    cafink Producer
    Apr 19, 1999
    3,043
    37
    Carl Fink
    Yes, the 2-disc metal case version is a bit more rare than the single-disc metal version.
  15. DannyS
    DannyS Second Unit
    Jul 9, 2001
    328
    cool! I have that one! :)
  16. Jacob_isham
    Jacob_isham Stunt Coordinator
    Oct 10, 2001
    52
    Good luck in your search justin, but i have to say the metal slip is over rated. I have the DVD-18 metal case version. All it is, is a rather pointless metal slip with T2 embossed on the front, that you have to pull off the amaray case before you can open it. It's not even a proper part of the case, It might be pretty cool if it was actually a metal case. But as it is they may as well have left this pointless slip of metal out and just released it in the amaray. Also i doubt the metal case version is very rare either, unless perhaps if you have the 2 disc metal case version (not sure about that one).
  17. JJR512
    Dec 11, 1999
    619
    I realize it's just a slip case. But given that the newer version is the same thing, only done in cardboard rather than metal, I'd rather have the metal version. For one thing, it's just cooler. For another, I can already foresee the cardboard version slowly deteriorating as it is removed/replaced onto the plastic case. But who knows, maybe the metal version will rust? [​IMG]
    [​IMG]
    Join the JJR512.com [email protected] Team and help cure what ails you. (Click here for more info.)
  18. Nate Anderson
    Nate Anderson Screenwriter
    Jan 18, 2001
    1,152
    If it rusts...I'd be wondering where you store your DVD's.
    "This is not a drill. This is the apocolypse!"
    My Extensive DVD collection.
  19. Esten
    Esten Supporting Actor
    Nov 15, 2000
    588
  20. Patrick McCart
    Patrick McCart Lead Actor
    May 16, 2001
    7,566
    195
    9,110
    Georgia (the state)
    Patrick McCart
    I got it for 10 bucks.
    [​IMG]
