Sonnie Parker
- Dec 11, 2001
I have the following SPL meter that was given to me. I was wondering how it compared to the Radio Shack SPL meter and it being digital would it work okay with my AVIA DVD?
There are 2 things that I question. The frequency response only measures down to 30hz, that won't be low enough, but I couldn't find the specs on the Radio Shack model so I don't know if it measures lower. The other is the accuracy, is +/-2dB acceptable?
Any suggestions or advice is appreciated.
Guy Kuo, I'd really like your response if possible.
SP
72-860 $149.00
Digital Sound Level Meter
Features:
A and C weighting
35~130dB measurement
2 ranges
Meets IEC 651 type 2 standards
3 1/2 digit LCD display
1/2" condenser microphone
Fast and slow dynamic response
Over and under range indicator
Maximum level hold
Internal oscillator for calibration
AC and DC signal output
Includes owners manual, 9V battery, carrying case, wind screen and adjustment screwdriver
Specifications:
Range 35~90dB (low), 75~130dB (high)
Resolution 0.1dB
Frequency range 30Hz~12KHz
Accuracy ±2.0dB at 1KHz (94dB level)
AC output 0.65V RMS corresponding to each range step
DC output 10mV/dB nominal
Dimensions 2 5/8" (W) x 9 1/2" (L) x 1" (H)
Weight 8 oz.
SP
Features:
A and C weighting
2 ranges
Maximum level hold
Specifications:
Resolution 0.1dB
Weight 8 oz.
