tempest or titanik?
Discussion in 'Home Theater Projects' started by Kevin Patterson, May 13, 2004.
  1. Kevin Patterson
    Kevin Patterson Stunt Coordinator
    Jan 14, 2004
    61
    im am trying to decide what to buy. Although the tempest is cheaper the titanik has more output. i have no limitations on box size an plan on goin ported for half musik and half movies. i want a low tuning 15-20hz and may build a sono tube. i will also buy a 250w amp not shure witch one can someone please give me some sudgestions as what to get?
    Kevin
  2. Chris Brock
    Chris Brock Second Unit
    Sep 13, 2003
    328
    I have used them both and I must say that I was more impresse with the Tempest. While the Titanic does have more linear xmax it seemed to reach its mechanical limits very easily and very often. The tempest on the other hand was much harder to bottom out. I would suggest going with the tempest.
    As for the amp, the PE 250w plate amp is a tried and ture unit. I have also personally used it and have never experianced any problems. PE is also one of the best customer service experiances I have had.
  3. Kevin Patterson
    Jan 14, 2004
    61
    Thanks Chris, what about going with more power somewhere around 340w? Would this be more suited for a tempest in a roughly 9^3 box tuned around 17hz or would this be too much power?
    Kevin
  4. Chris Brock
    Sep 13, 2003
    328
    I ran both the tempest and the titanic with the same 400wrms. there really seemed to be very little difference between the drivers. they are very close in performance. I just preferred the Tempest becuase it bottomed out less. that size of enclosure for the tempest would be excelent and with that tunning freq you would get a ton of spl.
  5. Mitch N
    Mitch N Stunt Coordinator
    May 11, 2004
    74
    People have had great success with the Dayton 15" Series II. It's even half the cost as well!
  6. Geoff L
    Geoff L Screenwriter
    Dec 9, 2000
    1,693
    Chris
    Where the enclosers the same for each driver, or different, and how so???
    Size and tuning of each??
    This could make a big difference on the Titanic bottoming earlier, or more often the the Tempest, especialy with that power.
    If box size is not a matter, then the Temest might be the better/cheaper choice.
    And budget wise, The Dayton that Mitch mentions is a good deal tho it may not serve your particular usage. Definitely worth a look tho! Cheap!
  7. Rory Buszka
    Rory Buszka Supporting Actor
    Jun 5, 2002
    784
    I think it's somewhat idiotik that people keep putting the "k" on the end of terms, instead of the proper "c". The proper spelling is Titanic. The same thing holds for "Isobaric".
  8. Kevin Patterson
    Jan 14, 2004
    61
    Tanks for all the replys i think i will be going with the tempest not the titaniC.
  9. KyleGS
    KyleGS Second Unit
    Feb 12, 2002
    342
    Gud chooice... :p)
  10. MichaelAngelo
    MichaelAngelo Stunt Coordinator
    Oct 22, 2002
    137
    Rory,
    'lil Texas trivia--is it ya'll or y'all ??
    [​IMG]
  11. Jason Dalton
    Jason Dalton Stunt Coordinator
    Feb 20, 2004
    174
    So is it Rory Buszca?[​IMG]
  12. Rory Buszka
    Jun 5, 2002
    784
    It's y'all. (I was born in San Antonio.)
