Tempest driver diameter cut?
Discussion in 'Home Theater Projects' started by Alex_P, Jan 29, 2004.
  1. Alex_P
    Alex_P Stunt Coordinator
    Nov 3, 2003
    133
    Hi all,
    I just ordered the Tempest driver. I just want to make sure how much wood should I cut since I don't have the driver w/ me yet? It's a 15" diameter right? What is the exact hole should I cut out? 14"? BTW, I will use a router (borrow from a frnd) to do the circular cut. Is it a good idea? or there is something else I should consider? Thanks in advance...
    Alex,
  2. perry web
    perry web Stunt Coordinator
    Dec 6, 2003
    64
  3. Alex_P
    Nov 3, 2003
    133
    wow, that is quick [​IMG] Thank you, Perry.
  4. perry web
    Dec 6, 2003
    64
    you are welcome. I just happened to check when you posted and had the link handy
  5. marc_manny
    marc_manny Stunt Coordinator
    Nov 25, 2003
    55
    Ok so you cut a hole 13 15/16", but if you are to recess it (flush mount) how deep do you route it? i.e. using a rabbitt bit I would think? 3/4"? Now since I would be using 3/4" MDF I would have to make the baffle thicker? Maybe 2 peice of 3/4" for a full 1.5"?
    thanks,
    Marc
  6. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,749
    480
    9,110
    Most people laminate two 3/4" pieces of MDF for the panel that has the driver installed on it. If you want to flush mount the driver, yes, it's 3/4" deep, so cut a 15" wide outer hole, and a 13 15/16" inner hole for the driver.
  7. perry web
    Dec 6, 2003
    64
    the drivers all have the seal on the front/top of the outside ring. most people mount from the outside so there is bare wood against metal. so, what do you people seal that with? silicon? gasket material?
  8. Patrick Sun
    Jun 30, 1999
    38,749
    480
    9,110
    Closed cell foam tape.
