Casey H
- Jul 29, 2001
Anyone have a diagram of how they wired their Tempest from VC's to the A/V or similar?
I may go with wiring a coil to each terminal, but then need help on how to "jumper" the terminal for parallel configuration. Also, do you use an single interconnect from the receiver and go into the amp left or right input, or use a splitter and go into both the left and right. Or, do you use line level inputs? Any benefit to one over the other?
Just trying to get some ideas churning!
Thanks, Casey
Thanks, Casey
