Tempest arriving today, question on mounting
Discussion in 'Home Theater Projects' started by JamesThompson, Dec 10, 2003.
  1. JamesThompson
    Nov 4, 2002
    44
    Would this stuff work well to sandwich in between the driver and the enclosure? It's the closest thing I could find to "rope caulk"
    w w w.homedepot.com/prel80/HDUS/EN_US/diy_main/pg_diy.jsp?CNTTYPE=PROD_META&CNTKEY=Products_2%2fPaint+%26+Wall+Coverings%2fCau lks+%26+Adhesives%2fPainter+Acrylic+Caulk&[email protected]@@@[email protected]@@@&BV_EngineID=ccdkadckedlegjdcgelceffdfgidgmk.0&MID=9876
    (sorry for the messed up link)
    Thanks again for the help.
    - James T
  2. Owen Bartley
    Owen Bartley Second Unit
    Nov 11, 2002
    487
    James, the link didn't work for me even after I fixed the www, but if its the foam tape they have, then thats what I used. Just make sure its closed cell, not open cell.
  3. JamesThompson
    Nov 4, 2002
    44
    Doh! Busted link.
    Fixed the link. The product is the "Thermwell 1/2" x 20' Caulking Rod" Catalog #107510
    - James
  4. JamesThompson
    Nov 4, 2002
    44
    Ahhh... Did a search for "Foam Tape" at HomeDepot.com and that looks like it came up with a few winners.
    Thanks!
    - James
  5. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,766
    489
    9,110
  6. JamesThompson
    Nov 4, 2002
    44
    Nice! I'll be attempting the same thing tonight to finish off my first Tempest project.
    And I'm really liking the $3 price tag on the foam tape. [​IMG]
    - James
  7. Allen Ross
    Allen Ross Supporting Actor
    Sep 30, 2002
    819
    i always have put a bead of silicone on the enclosure and driver and let them dry and screw it up works like charm.
  8. Owen Bartley
    Nov 11, 2002
    487
    Yep, that tape that Pat used it what I used too. It works well, and isn't a permanent seal, like silicone or caulk might be. Of course, that won't matter if you don't plan on opening it up again. One thing I did notice on mine was that the tape is probably good for one use, and if you pop out the driver for anything you might want to re-tape. Mine was pretty seriously compressed and I don't know if it would have made a great seal the second time. But hey, for a few bucks a roll, who cares?
