Temperature of the Denon 2805
Discussion in 'AV Receivers' started by Kevin_F, Feb 3, 2005.
  1. Kevin_F
    Kevin_F Stunt Coordinator
    Dec 1, 2004
    246
    How hot does the 2805 run? Should I expect to put this on the top of my rack, or can I put it at the bottom, with other equipment stacked above it?
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    Hmm, I would just make sure it has all the breathing room indicated in the manual at a minimum. I gave my Denon 4802 generous space compared to what was in the manual.
    7 high current amps you know.. [​IMG]
  3. Vader
    Vader Supporting Actor
    Mar 19, 1999
    810
    24
    Derek
    I am using a Denon 2105 (less power than yours, I know), and I keep about 5" cleared above, 2" on either side, and 4" in the rear with air holes in the cabinet, and it runs cooler than the Marantz S580 that preceeded it...
  4. Mort Corey
    Mort Corey Supporting Actor
    Nov 21, 2003
    981
    I've got the 3805 in a cabinet with slightly more clearance than Derek and even after a few hours of near reference level movies or music, it's only slightly warm to the touch.
    I'd still put it on the top vs a bottom shelf.
    Mort
  5. Kevin_F
    Dec 1, 2004
    246
    Thanks, I just wanted to know how best to set up my components
