Teenage Mutant Ninja Turtles (2003+) "edited" versions?
Discussion in 'TV on DVD and Blu-ray' started by Jay Pennington, Jun 2, 2005.
  1. Jay Pennington
    Jay Pennington Screenwriter
    Apr 18, 2003
    1,189
    The online listings for many volumes of this series have "(edited)" attached to the title. Anyone know why? Are there edited and non-edited versions? Or is it simply a matter of stitching together multi-episode storylines into one long "movie"?
    Thanks!
  2. Travis W.
    Travis W. Second Unit
    Jun 11, 2004
    305
    I've got all the DVDs and none of the episodes are edited whatsoever. However, some of the "opening monologues" from the Return to New York episodes are missing. But that's it, they're great discs if you're a fan of the show, definitely not worth missing.
  3. Jeff Jacobson
    Jeff Jacobson Cinematographer
    Dec 24, 2001
    2,116
    As far as I know there is only one version of each DVD. But on some of the multi-part episodes they've removed the segment before the opening credits (where one of the characters tells you what happened on the previous episode).
  4. Jay Pennington
    Apr 18, 2003
    1,189
    Thanks!
