Technics Overload
Discussion in 'AV Receivers' started by Scott Andrew, Jan 17, 2005.
  1. Scott Andrew
    Scott Andrew Stunt Coordinator
    Nov 9, 2004
    63
    So my uncle has a Technics SA-AX540 amp (rated at 100 watts per channel in to 8 Ohms) and he was using two Cerwin Vega CLSC-12 towers (8 Ohms, 300 watt peak)) for the fronts. Now his amp is saying overload. There are no loose wires crossing and there is plenty of air around the unit. The next day I even completely took the unit out of the cabinet and disconnected every speaker and component in the system and took the amp in to the bedroom and plugged it in and it still said Overload. So is the amp fried?
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    Fried... yep. It happens...
    Time for a new one, or off the a bargain repair outfit. If you try to fix it yourself. Look for bloated caps on this one.
