Mat_M
- Jan 3, 2003
The bottom line is, I need to know what kind/type of signal comes out of a receiver's "subwoofer" RCA connector. What is the frequency range (10-150Hz?)? What is the typical amount of power sent? How is the signal processed from DVD to the connector? Will a low/medium-end receiver send out a crappier signal than a high-end receiver? If so, how? Narrower range of frequencies? Noisier signal? And ultimately, how will these differences affect the subwoofer's audio output?
If you can, be as technical as possible.
The motivation behind this series of questions is this: I consider myself an intermediate level HT person looking to upgrade. My first upgrade picked out is an SVS 16-46-PC+ subwoofer. I want to utilize this subwoofer's frequency range as much as possible, but I'm concerned that my receiver won't be sending it a wide (and low) enough range. I currently have a Harmon Kardon AVR300.
Thanks for the help,
Mat
Mat
