Technical Question Regard a Digital SACD Feed
Discussion in 'Archived Threads 2001-2004' started by David Schamis, Jul 28, 2001.
  1. David Schamis
    David Schamis Stunt Coordinator
    Jul 21, 1999
    55
    If and when the studios figure out a copy protection standard and SACD players are allowed to provide a direct digital feed to a pre/pro, will current pre/pros on the market be able to be software upgradable to handle the new digital format, or would one need to replace their hardware?
    Thanks in advance,
    David
    [Edited last by David Schamis on July 28, 2001 at 02:57 PM]
  2. StaceyS
    StaceyS Stunt Coordinator
    Feb 11, 2000
    180
    quote: will current pre/pros on the market be able to be software upgradable to handle the new digital format, or would one need to replace their hardware?[/quote]
    Depends on what product you own. it will require a new interface, which is hardware. It may require new DSP, etc.
    You will probably need to buy all new hardware.
    There are a couple companies doing that now if you don't mind spend $15k-$20k.
    [Edited last by StaceyS on July 28, 2001 at 02:27 PM]
