Techflex & Heatshrink -- What Size to Use?
Discussion in 'Home Theater Projects' started by Cynthia Binder, Aug 10, 2004.
  1. Cynthia Binder
    Aug 31, 2003
    18
    I'm in the process of completing a remodel where I did whole house audio/video wiring in 11 rooms and wired for a home theater system. All wiring was brought to a control center room which is accessible behind the home theater components and other electronics for connection.
    I have a lot of RG-6 cable and Ixos 14/4 speaker wire that I want to cover with Techflex and terminate with heatshrink for a cleaner look. What size stuff should I use? I don't want the Techflex to be loose or sloppy, yet I don't want a hassle in putting it on. Also, is 3/4" heatshrink the right one to use?
    Thanks!
    Cynthia
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
    Cynthia,
    Can’t help you with the techflex ‘cause I’ve never used it, but the heat shrink is pretty simple. Just measure the OD of the RG-6 and get some shrink that’s about 1/8” larger.
    If your cable is already terminated with the “F” connectors, their width is what you’ll have to go with. Keep in mind, however, that if the shrink is about 1/ 4” or more larger than the cable, there’s a good chance it won’t shrink down tight over the cable.
    Come to think of it, I imagine the techflex needs to be a little smaller than the cable’s OD. Otherwise it will be loose.
    Wayne A. Pflughaupt
  3. Cynthia Binder
    Aug 31, 2003
    18
    Thanks Wayne --
    Techflex says the specs are as follows:
    1/4" size fits 1/8" - 7/16" cable
    3/8" size fits 3/16" - 5/8" cable
    1/2" size fits 1/4" - 3/4" cable
    My Belden RG-6 is about 1/4" in diameter and the speaker wire is 5/16". So according to those measurements, all the sizes would fit, however, I would assume the smaller two would be snugger.
    None of my cables are terminated yet, so I just have to worry about the cable size.
    I talked to the folks at Partsexpress and Wirecare.com and both said their heatshrink is 3:1. Partsexpress told me to get the 18 mm for what I am doing which is a little less than 3/4". That sounds different than what you mentioned.
    Anyone else have ideas or used the stuff???
    Cynthia
  4. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
    PE’s recommendation should be fine, especially if you’re shrinking over techflex. My recommendation was for the smallest size you could use without techflex. The main thing is that you don't want it super-snug or barely-fit going on, or it will split when you shrink it.
    Wayne A. Pflughaupt
  5. David K.
    David K. Second Unit
    May 14, 2004
    260
    im very familiar with tech flex,
    The specifications on the website are dead on, But if you choose the smaller size of the two then you get little holes in the sleeving, if you choose the mediom size one itll fit nicely,
    But DO NOT get the 1/2" for a 1/4" cable, even if the specs say that the 1/2" will fit 1/4" it'll come out loose.
    I have a tutorial online with pics of customizing an exotic cable, you may find it interesting
    http://www.geocities.com/RnB180/diy.html
    Ill take some more pics and post examples for you to see different sizes.
  6. David K.
    May 14, 2004
    260
    1/4" black techflex over 4x14awg leads
    [​IMG]
    3/8" blue tech flex over 3/8" canare 4s11
    [​IMG]
    1/4" black flex over 3/8" canare
    [​IMG]
    dual sleeved,
    3/8" blue flex + 1/4" black flex over canare
    [​IMG]
    1/2" 2-1 dual wall heatshrink + 1/2" red 2-1 regular red shrink
    [​IMG]
    3/8" 2-1 heat shrink for both the boot and leads.
    [​IMG]
    3/8" 2-1 heat shrink for boot, 3/16" 2-1 heat shrink for the 14 awg leads.
    [​IMG]
