TB 6.5" Subwoofer - By The Way...
Discussion in 'Home Theater Projects' started by Rory Buszka, May 11, 2004.
  1. Rory Buszka
    Rory Buszka Supporting Actor
    Jun 5, 2002
    784
  2. JohanD
    JohanD Stunt Coordinator
    May 22, 2003
    180
    is this unit the XBL^2 unit?? IE the extremis variety for TG?
  3. Kenneth Harden
    Kenneth Harden Screenwriter
    May 13, 2002
    1,365
    Wow, very cool.
    If I had woodworking skills, I would love to make a micro sub and see what happens.
    I like the idea for a sonotube - imagine building a few of those into architectural colums in a house!!!
  4. RobLJ
    RobLJ Stunt Coordinator
    Jan 7, 2004
    81
    I wonder what 4 of those would sound like in one cube. I'm about to start a sub project. It's kind of tempting.
  5. Mitch N
    Mitch N Stunt Coordinator
    May 11, 2004
    74
    Thats an awesome looking woofer! It makes me wonder what I could build with that.. Granted it would never be in a HT setup, but for perhaps a book shelf system or perhaps even for a computer, I think it could be perfect.
    Or then again perhaps a 3-way with a couple on each channel could make for an interesting tower speaker. [​IMG] [​IMG]
  6. Mike SJ
    Mike SJ Supporting Actor
    Nov 10, 2003
    718
  7. Mitch N
    May 11, 2004
    74
    Does anyone want ot post up some different models of this using different enclosures? Sealed, ported for lowest freq, ported for high output, IB...
  8. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    wow thats cool, theni can just get the sonotubes at Home Depot (largest they have is 12") and build myself a mini-sub for a bedroom system or somethin
  9. Geoff L
    Geoff L Screenwriter
    Dec 9, 2000
    1,693
    Damn
    I waited and waited for these things to come in some where, The now defuct Nuera as I understand, and then PE mentioned a month plus back that they where going to carry them.
    I finally could not wait any longer and started a small box sub using a ED KX.22 10". Still not finished, got a bad CV-300 amp and waiting for it's replacement.
    I'm still pissed that these are now in! [​IMG]
    The TB 6.5" plan was a dual Isobaric push pull using 4 of the TB 6.5"-drivers. Some where I have the sim sheet and it looked mighty good. Would have had people saying, that bass is coming out of that little thing!
    Argggg...
    I may still do something with some of them, have to calm my ass down first...!
    As soon as the very kind and always on top of things "Rory B" posted this, my blood started to boil!!!
    They seem to work well in all sorts of designs, go play with some programs and check'em out, especially using multipuls of them..
    Edit: Also did a box with 4 of them in just a push pull set up, simalar to the B-4 SVS look..
    Oh vell, life goes on..![​IMG]
  10. Mike SJ
    Nov 10, 2003
    718
  11. Mitch N
    May 11, 2004
    74
    The only problem I see with this driver is the extremely long port lengths required for it to go low. It may require an extremely complex slotted port design which would have to zig zag within the box to reach the required length.
    What about a TL enclosure for this? I don't have access to model that, do any of you? A piece of PVC pipe or sonotube would work in this case.
  12. Geoff L
    Dec 9, 2000
    1,693
    That why I mentioned using multipuls of them in the same encloser. Of course you could PR them, but reg porting can fit if you find the right number to use and can get the ohm load wired correctly.
    Using 4 in a push pull gets you up aroud or over 1-cube with out subtracting for drivers or ports. Might as well go EBS and add another 30 to 50% and tune it lower. I'm trying to remember off the top of my head so these may be off a bit.
    But no question something pretty interesting could be built.
    And the TL, yes why not....
  13. Bob Reimer
    Bob Reimer Agent
    Sep 17, 2000
    33
    Neither Tangband nor PE have licensed XBL^2 as far as I know.
    Bob
  14. GeoffM
    GeoffM Agent
    Jan 15, 2003
    30
    Has anyone come up with a good car sub with this? perhaps two in a seal enclosure [​IMG]
  15. Frank Carter
    Frank Carter Screenwriter
    Mar 12, 2002
    1,187
  16. kai m
    kai m Auditioning
    Apr 16, 2004
    8
    Hoffman's iron law still rules. However horn loading presents possibilities....
  17. JustinSC
    JustinSC Extra
    Aug 16, 2002
    17
    Sorry if this is off the topic, but what exactly is a passive radiator for? I understand the concept I think, use energy from another speaker's movement to supply its own movement? I have seen these speakers come up the last few days (this thread and the new GR sub thread) not understanding them.
  18. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
  19. Shawn Solar
    Shawn Solar Supporting Actor
    May 12, 2001
    763
    Anyone run any sims yet. Ported would be excellent but the box is just too small. Sealed just doesn't have the bass response for HT listening.. fine for near field listening. Now I simulated parts express 8" passive but it just simply wouldn't work. I really wouldn't want to use 10" or larger passive... it would make using a smalldriver/cabinet redundant. Anyone know a decent 8" pr? I figure about 17L tuned to about 28hz. Nice response at 100db across the board with a box no larger than a 1/2 cube Just would like to keep it small as possible. Now if one were to integrate this into a tower/bookshelf it could work with port.
  20. kai m
    kai m Auditioning
    Apr 16, 2004
    8
    I think you need min 4x excursion of the driver, for a passive radiator. Wild guess is that it would need need at least a 30 mm peak to peak PR in an 8"
