T.V problem (1 Viewer)
Keith_R
FL
Kyle
I have a 13 inch Magnavox TV that I use for my bedroom. The TV itself is 6-7 years old. Since a few days ago the TV has been doing something wierd. The picture is completely blacked out except for one small horizontal strip which shows what is on the screen. That small strip is all that you can see of the existing picture. To be quite frank and exact it looks like a huge letterboxing effect is on the screen. This TV is not used for movies at all, it is used as a strict 4:3 viewing screen. What is going on with my TV? thanks.
Allan Jayne
Some component has failed or fallen out of adjustment such that the vertical movement of the electron beam is no longer correct. You may be able to compensate by adjusting the vertical size control, the same control used to adjust overscan or that can be used to do the 16:9 squeeze.
If you cannot compensate for this, calling a serviceman is probably more expensive than the TV set is worth.
Video hints:
boreli
