System Tray Icon Removal?
Discussion in 'Archived Threads 2001-2004' started by Kevin_Graham, Feb 16, 2003.
  1. Kevin_Graham
    Kevin_Graham Stunt Coordinator
    Mar 1, 2001
    131
    How do I remove the Windows Messennger icon from my system tray? I'm running XP and despite not using messenger I have been unable to remove this icon.
    Kevin
  2. Tekara
    Tekara Supporting Actor
    Jan 8, 2003
    783
    try going to add/remove programs and un-installing messenger.
  3. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    If you know your way around the registry you can do this:
  4. Thi Them
    Thi Them Producer
    Apr 20, 1999
    3,649
    You might be able to disable it in System Configuration Utility.
    ~T
  5. Mike LS
    Mike LS Supporting Actor
    Jun 29, 2000
    838
    Is this Windows Messenger or MS Messenger?
    I didn't know Windows Messenger had an icon in the tray.
  6. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    Without going into the registry try this.
    Do a all files search(hidden files included) for a file under the name.
    "sysoc.inf"
    You should see a bunch of entries with a HIDE extension. What this does is hide the entry from the add/remove window.
    this is the line you are looking for.
    "msmsgs=msgrocm.dll,OcEntry,msmsgs.inf,hide,7
    Delete the word "hide" and one of the "," then save and exit.
    Now goto add/remove programs and msn messenger should be there
    Brent
  7. Hanson
    Hanson Producer
    Nov 1, 1998
    4,694
    150
    Hanson
    Open Messenger and go into the preferences. Check off the box that allows it to start with windows.
    You caould also go into the control panel, go to add/remove programs in the setup tab and deselect messenger.
  8. Kevin_Graham
    Mar 1, 2001
    131
    brentl - Thanks! It worked perfectly.
    Kevin
