Sync problems with DiVX file
Discussion in 'Archived Threads 2001-2004' started by Jeff Kleist, Sep 9, 2002.
  1. Jeff Kleist
    Dec 4, 1999
    11,267
    I have a DiVX file where the audio progressively goes more and more out of sync. At the beginning it's fine, but by the end, we're talking close to 2 seconds of lag. Any idea on why?
  2. Mark Hsieh
    Mark Hsieh Agent
    Aug 16, 2002
    49
    Bad encoding most likely..does it happen on any other machines?
  3. Jeff Kleist
    Dec 4, 1999
    11,267
    yes, it's replicateable on 3 different machines, 3 different configs
    Premiere doesn't like DiVX, and given the progressive nature of the out of syncing resynching may be hard. Any suggestions for remuxing a new audio track?
  4. John_Berger
    John_Berger Cinematographer
    Nov 1, 2001
    2,489
    I've had that happen as well. The only thing that I can guess is that the encoder incorrectly sets the video frame rate.
    Look for a tool called AVIFRATE, I believe. It's a tiny tool whose sole purpose is to adjust the video frame rate. I've used it many a time to adjust sync problems.
    Now, the issue that I've run into is when it's out of sync in the beginning, good in the middle, then out of sync in the other direction at the end. I'm not sure how to account for that.
    Is your audio good from the very beginning? If so then AVIFRATE should help to correct the problem.
  5. Jeff Kleist
    Dec 4, 1999
    11,267
    Yes, the audio is good at the beginning. by my estimates, it drops another frame every 2 minutes putting it over 2 seconds off at the end of 45min.
    I'll give it a whirl
  6. Jeff Kleist
    Dec 4, 1999
    11,267
    Success! I thought that was the problem, but had no idea how to fix it because Premiere doesn't like DiVX [​IMG]
    boy, that .003fps makes a big difference [​IMG]
  7. John_Berger
    Nov 1, 2001
    2,489
    Sure as hell is sensitive, isn't it? Glad it worked!
    I'm confirming right now (actually, it's probably done) whether or not MSP 6.5 can handle DIVX. All of the options were there, but who knows what will happen (if anything) during the encoding. I'll find out when I get home.
  8. Peter D
    Peter D Stunt Coordinator
    Aug 16, 2000
    232
    I'm glad you brought this up, Jeff, as I've been having the same general problem myself. Hopefully this utility will take care of it.
  9. John_Berger
    Nov 1, 2001
    2,489
