swan surrounds
Discussion in 'Speakers & Subwoofers' started by matt_matocha, Aug 8, 2004.
  1. matt_matocha
    matt_matocha Extra
    Jul 24, 2004
    16
    I think ive decided upon the swan series of speakers. I plan on piecing a 5.1 setup over this year and wanted to start out with the 2.1's, then center, then 5.1's for mains, and i have some ideas for subs but none are set right now. My question is would the 2.1's be better for the surrounds or the actual surrounds offered from swan? Just didnt want to buy the 2.1's if i wouldnt really want to use them as rears if the actual surround are the better option. Thanks
  2. SethH
    SethH Cinematographer
    Dec 17, 2003
    2,867
    The 2.1's will make very good surrounds. Many people on the forum have 2.1's for surrounds. Many people also have the dipole surrounds from Swan. I don't think I've heard too many complaints about either. It's really just a matter of preference. Some people like the monopoles, some like dipoles or bipoles. Your upgrade path makes good logical sense and will give you a great system in the end. If you get to the final 5.1 system and think dipole would be beneficial you could try to sell your 2.1's and probably wouldn't be out too much.
  3. matt_matocha
    matt_matocha Extra
    Jul 24, 2004
    16
    thanks for the input. what are the advantages to going with a dipole over the bipole/monopole speakers? is it just that they are less directional? thanks again
  4. Rob Kramer
    Rob Kramer Second Unit
    Mar 30, 2004
    435
    Matt
    You should really do a search. We just had this topic come up a week or two ago.
  5. Ben Mecham
    Ben Mecham Agent
    Jul 20, 2004
    25
    matt,
    I think it will depend on the room size and orientation. Since the 2.1's are more directional than the bipoles, they would be best used if they could be placed slightly further away from the listener, or else you could be limiting your "sweet spot" areas. If the seating is very close to the speakers, bipoles might be the way to go, allowing for more variety of optimal listening positions, as far as the surrounds go, IMO.
  6. Burklund
    Burklund Stunt Coordinator
    Jul 27, 2004
    90
    bipoles?
    monopoles?
    dipoles?
    what does all that mean?
    I'm leaning towards the swans too. I'll probably get the 5.1s or 6.1s for the front main speakers, a center, and still undecided about the rears for surround sound.
    now whats all this "poles" about?
  7. SethH
    Dec 17, 2003
    2,867
    Search the forum or the primer for detailed explanations . . .
    Monopole = "regular" speaker
    Bipole = two speakers in one box angled away from one another IN phase
    Dipole = two speakers in one box angled away from one another OUT of phase
