SW21 errors STILL! (1 Viewer)
Mike Franklin
I got the tree removed yesterday and now I get 100% sig now, but still no dish 500. When I do the swithc check now I get 119 even,119 odd,x,110 even. I have done every trick in the book, I even put foyl over the 110 lnb to make sure I am I am getting 119 sat, but as soon as soon a I put the switch back on I lose all signal, the only way i can get a signal is with the switch in place and I know that isnt how it should be. What am i doing wrong, please help.
Robert_J
Mississippi
When you don't put the switch in, are you connecting the 119 LNB and checking which channels you get? Same for the 110? If they both work correctly, then it's probably the switch. If not, swap LNB positions or swap cables (if you have more than one). Swapping LNB positions, if the problem at 110 goes to 119, then it's the LNB. If it stays at 110, then it's cable or a connector.
-Robert
NHCondon
