SVSubwoofers accurate?
Discussion in 'Archived Threads 2001-2004' started by Nick L, Dec 9, 2002.
  1. Nick L
    Nick L Second Unit
    Nov 14, 2001
    283
    Are SVS subs the best because they are the most accurate or is it that they can just produce insane amounts of bass? OR is it that they are accurate with insane amounts of bass. I'm looking for a new subwoofer, and am not having lots of luck finding one I like. I don't need 100db at 20Hz but when there is bass sent to the sub I want to hear bass out of the sub. I've listened to many brands and nothing in my price range is anywhere close. I'm trying to stay around the $500 mark. So I initially wasn't going to buy a svs because I thought I could find something cheaper, but its turning out not to be so. I just want an accurate sub, is SVS it?
    Nick L
  2. VinhT
    VinhT Second Unit
    Feb 14, 2002
    357
  3. Donald Shrum
    Donald Shrum Stunt Coordinator
    Dec 24, 2001
    182
    I have an REL Strata III sub thats fast and acurate. Check the for sale forum for details. Slightly over you budget but this sub retails for over $1800.
    Donald
  4. Edward J M
    Edward J M Cinematographer
    Sep 22, 2002
    2,031
  5. Eric Wood
    Eric Wood Stunt Coordinator
    Oct 4, 2001
    54
    http://www.vmpseurope.com/e/add005.htm Tune it by taking putty from here
    http://www.vmpseurope.com/e/add007.htm
    Buy it for about $520 from an authorized dealer In California
    The New Original Subwoofer
    Frequency Response: +0, -3dB, 20Hz to 600Hz (19Hz with optional Megawoofer)
    THD: 2.5% max. 20Hz to 600Hz with 1 W drive
    Sensitivity: 90dB/1W/1m
    Maximum undistorted output: 112 dB/1m for 2.5% THD
    Drive complement: 30cm polycone active w/butyl surround (30cm WCF active with Megawoofer), 38cm slot-loaded passive radiator
    Recommended Crossover Range: 60Hz - 300 Hz
    Impedance: 8 Ohms (Dual Voicecoil version 8 Ohms per coil)
    Power Requirements: 20W - 200W rms (300W with Megawoofer)
    Dimensions: 20 x 27 x 17" (HxWxD)
    Weight: 43kg
    Finishes: genuine oak veneer, light or dark, 25mm MDF construction, black grill; satin black or piano black finishes on special order
    Internal wiring: 12 gauge Monster Cable
