SVS Withour Bass Plate: Anyone Doing It?
Discussion in 'Speakers & Subwoofers' started by Arthur S, Apr 11, 2006.
  1. Arthur S
    Arthur S Cinematographer
    Jul 2, 1999
    2,568
    It's interesting that some of the SVS ads show the sub without the bass plate. Is anyone using it that way?
  2. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Are we talking cubes or cylinders?
    The PB-10 doesn't have a base plate that sits on the floor because it is front firing/ front ported, if that is what you're talking about?
  3. Paul Mor
    Paul Mor Stunt Coordinator
    Aug 3, 2004
    82
    I believe it shows it that way only so you see the woofer. I did however read a recent post where someone suggested it because the sub was in sort of a recessed area. I wouldn't recommend it.
  4. MikeNg
    MikeNg Second Unit
    Jan 22, 2004
    440
    I am. PB12-ISD/2 with drivers facing the wall. It was the best sound for that location. When I had a 16-46 CS+ I tried it with it on its side with pretty good results. Placement was a little tough like that though.
    Mike
  5. steve nn
    steve nn Cinematographer
    Jan 12, 2002
    2,418
    Actually plenty of users are. It all depends on your room and placement what your best FR response will be. In most cases it might change the curve little, but nothing major. Like I mentioned though, it's very room dependent if it's worth it or not? Some also like the look of the driver facing out.
