SVS Tuning Question
Discussion in 'Speakers & Subwoofers' started by MikeWHA, Feb 20, 2005.
  1. MikeWHA
    MikeWHA Extra
    Dec 30, 2004
    19
    Quick question from the SVS web site. I am contemplating the 25-31PCi or the 20-39PCi. The website states: "The PB1-ISD has single woofer so as you might expect, it's virtually identical to a 22Hz tuned version of our 25-31PCi subwoofer." Can someone please explain to this newbie how I would get a 22Hz tuned version of the 25-31PCi. Does anyone know how this will compare to the 20-39PCi? Any recommendations - I'm thinking that for the extra $50, I should just go for the 20-39, but not if the 25-31 tuned to 22 is adequate. Here's my set up: Rocket 550s up front and in back along with the 200 Bigfoot, Pio 1014. Room size: 18X16X10 fully opened on one side to a 25X16 kitchen. Thanks.
  2. MichaelPR
    MichaelPR Second Unit
    Nov 16, 2003
    401
    I think you should stick with the first choice as I believe you will get higher spl in your room with that sub. Going any deeper really depends on what type of material you plan on playing. Are you a big fan of organ music?
  3. SethH
    SethH Cinematographer
    Dec 17, 2003
    2,867
    The 25-31 tuned to 22Hz is a nice compromise between the 25-31 and the 20-39. You'll get a little more extension, but you won't lose quite as much SPL as you will with the 20-39. Either will probably suit you fine. You might e-mail SVS, explain your situation (room size, etc) and see what they think.
  4. Axu R
    Axu R Agent
    Dec 18, 2004
    30
    25-31 @22Hz would be nice, as it's a lot smaller than 20-39. I'd go for it. Btw PB10 is tuned at 17.5Hz I believe.
  5. LloydM
    LloydM Agent
    Dec 29, 2002
    38
    How do you tune the SVS subs to specific Hz? Or is this info that is passed to SVS prior to the purchase?
  6. Ilkka R
    Ilkka R Second Unit
    May 19, 2004
    270
    Notice that [email protected] gives up (quite a lot) to it's bigger brother especially at 20-25Hz range.
    Yes, you have to inform SVS that you want different tuning.
  7. MikeWHA
    MikeWHA Extra
    Dec 30, 2004
    19
    After talking to SVS, I decided to go with the 20-39. Yes, they will tune it to 22 for you but with the size of my room, the salesman recommended the 20-39. At only $50 more than the 25-31, it became an easy decision.
