Steven Or
- Apr 27, 2003
Great forum!
I was about to buy the SVS PC Plus 20-39. Before I do a few questions.
Are there any ever coupon codes or discounts on them? I did check the b-stock and they have none.
Is there any other sub I should consider other than this one? Amp is a Denon 4802, Klipsch Forte IIs in the front, Klipsch KLF C7 in the center, Klipsch KG5 in the rear, and Boston Acoustics DSi460T2 on the sides.
Placement question; Everything I read says subs should be in the corner which I can do. Does it have to be on the floor for best sound? Could it be above the front speaker on top of the Forte II. I do not mean I would have it standing on top of the speaker but I am building the entertainment center from scratch. Would a sturdy shelf on top compromise sound quality?
Thanks in advance.
Thanks in advance.
