MikeDierbeck
- Apr 15, 2002
Hello there-
I did some rearranging of my home theater room. I have a 65" Mits Widescreen TV and it looks best at about 16 feet away, so I moved my seating arrangement around so that I am seated 16 feet away from my TV. My only corner available IN FRONT of my seating arrangement for the SVS 20-39PCi ends up being 17 feet away. When I calibrated the sub to about 87, I wasn't getting that "punch" that I received when I was seated about 14-15 feet away from my sub. I am thinking that maybe I am too far away from it.
The only possible corner would be about 5 feet BEHIND my seat. Of course, I need to find a longer cable because that would run from the receiver on one end of the room to the other end of the room.
I do have a computer desk that kind of creates a corner with another large desk, but I don't know if this can really be considered a corner rather than just strategically placed desks. If I put it there, it would be about 4 feet in front of me and to the side. I'm not sure what I should do.
I'm not sure if I should just turn the Sub up a little more and keep it 17 feet away from me. I am able to set the distance of the sub into my receiver's settings, so I wouldn't think that distance would have anything to do with sound ... I'm thinking that acoustically, that corner might just not be good enough. By the way, the sub is in the right corner, about 2 feet away from the Front right speaker.
Any suggestions would be helpful.
Mike
Mike
