Are the original PC's being discontinued? I would imagine so since you can get more for less in the PCi's. Great job incorperating the BASH technology too!
Now the real waiting begins! I am on board for one of the 25-31s - hopefully tuned to 22Hz! Not real sure how I am going to make it through the next few weeks until it arrives. Kudos to Ron and Tom and all the SVS people for seemingly accomplishing what is basically unheard of in the business world today - improving the product AND lowering its cost.
What I would really like to see is a powered CS plus series. It looks like they can use the same enclosure as the CSi with the new three port top from the plus.
Then you would get the better driver and some a tuneable port frequency. One thing that is odd is that with the plus series, each marginal step in extension only costs another $50, but with the other subs it is about a $100 differential between subs within a line. Should the difference be the same since the only thing that is changing in each case is the height of the enclosure and port lengths?
Hi guys, it appears as if HTF and SVS got our wires crossed a tiny bit. No blood,no foul though...
give us a few hours to tidy up the page and we'll begin talking about preorders and the contest.
1)the PC+ will use 3 3" ports,the new dB12 driver and a completely different BASH amp It's brother in bass is the CS+. The PCi brother in bass is the CS.
2)the PCi is the powered version of the CS series....it's not designed to match the CS+ performance wise.
$549-$749, 320+ BASH watts,new improved driver...same old SVS customer support...anyone interested?
TV
I've seen quotes about the performance of the 'plus' line being 80% of the Ultra. How close will the perfomance of the PCi be to that of the PC+? I've been waiting for the introduction of the PC+ but if the new PCi gets close then maybe that's the better option, especially since you've said that the PC+ won't be around til 'maybe' late spring.
Can the new amps in the PCi line be made to fit the original PC subs? In other words, is it possible to upgrade the driver and amp on the PC, thus making a PCi?
>>>TV,
I've seen quotes about the performance of the 'plus' line being 80% of the Ultra. How close will the perfomance of the PCi be to that of the PC+? I've been waiting for the introduction of the PC+ but if the new PCi gets close then maybe that's the better option, especially since you've said that the PC+ won't be around til 'maybe' late spring>Can the new amps in the PCi line be made to fit the original PC subs? In other words, is it possible to upgrade the driver and amp on the PC, thus making a PCi?
Congratulations Tom and Ron on the new additions! It almost sounds like we should be passing out cigars!
What's the lowest the 25-31 PCi can be tuned - 22 Hz?
David
