Aaron H
- Jun 28, 2001
Hello,
I just got my 25-31PC+ hooked up and have a question on the crossover on the sub.
If I have all of my speakers set to small on the receiver and crossed-over at 80Hz and I also have the sub crossover set at 80HZ, should I be hearing a difference when I toggle the sub’s crossover enable/disable switch? I do hear a difference in sound from the sub, but if I am thinking correctly and if the receiver is set up correctly, I was thinking there should be no difference.
Thanks!
Aaron
Thanks!
Aaron
