Gary Shipley
- May 28, 2002
I'm really stuck and need some help with a decision. I want to upgrade my JBL pb12(250 watts) with a SVS. I'm torn between the PB12 Plus and the Plus2. The room is 26' long and 14' wide with no open doorways. I contacted SVS and they told me the PB12 Plus would probably work fine in the room, but if I liked to watch action movies at reference level, I should go with the Plus2. The problem is,I'm not sure what is considered "reference level". I watch my movies fairly loud but I don't know if they are at reference level.I personally think the PB12 Plus would work quite well since it is twice the wattage I'm using now. I just need nudge in one direction or the other. Thanks
