SVS on riser
Discussion in 'Archived Threads 2001-2004' started by Todd_B, Jul 16, 2002.
  1. Todd_B
    Todd_B Second Unit
    Jul 16, 2000
    381
    Guys -- I'm finally getting around to building my first dedicated HT room [​IMG]
    I plan on building a riser that will elevate the TV/fronts/gear rack and my SVS. Which got me thinking...
    Will elevating my sub on a riser have any negative repercussions?
    I plan on building the riser w/2x8 and 3/4 ply. It will be sitting on a carpeted concrete floor.
    Any input would be greatly appreciated.
    Todd B
  2. Tim Hoover
    Tim Hoover Screenwriter
    May 27, 2001
    1,422
    Todd, you shouldn't have any necessarily negative repercussions, because the materials you are using for the riser are the same usually found in floors.
    That being said, you may lose a bit of output due to the extra air space under the SVS, but that's easily compensated for with a turn of the volume knob. Just make sure that the riser is coupled to the floor well (either by sheer weight or physical fasteners) so it doesn't rattle during bass-heavy passages...
  3. Tom Vodhanel
    Tom Vodhanel Cinematographer
    Sep 4, 1998
    2,215
    8
    Tim is correct, in theory. In practice...the lose of headroom would be so small it might not even demand you recalibrate...but as Tim mentioned...it could.
    TV
  4. Tim Hoover
    May 27, 2001
    1,422
    Holy smokes! The Man himself backed me up!!! I can feel my head getting bigger right now...
  5. Todd_B
    Todd_B Second Unit
    Jul 16, 2000
    381
    Thanks for the input guys. I now can build my stage w/o worry [​IMG]
    Todd B
