Sam_h
- Sep 10, 2001
My norh 4.0 ceramic video package is coming next week and I need to get a sub. I have decided I want to go with either the 20-39CS or the 25-21CS. My problem is that I live in a small studio about 16x10 for the main room which has a large opening to another 120 sq ft. I will be listening to movies at a moderate volume,nothing loud enough to get me evicted. I was also looking at the plate subs from parts express and was thinking of getting either the #300-793 250W sub or the #300-792 120W sub or the #300-794 250W sub. So these are my questions
1. Which sub should I get. I'm not really concerened with something super loud, just something that goes deep and is tight.
2. Is there any difference between the #300-794 and the #300-793 other than the remote?
3. Can anyone recommend better amps in the same price range?
4. What should I do about the bass boost, should I make the modification to set the boost to 0?
