SVS CS-Ultra Power Handling
Discussion in 'Archived Threads 2001-2004' started by Sandra B., Sep 5, 2002.
  1. Sandra B.
    Sandra B. Extra
    Aug 19, 2002
    24
    ¿Did anyone knows the max rms watt power handling of the SVS CS-Ultra? That monster driver seems unbeatable! [​IMG]
    ¿It's the difference between the Ultra and the Plus series very noticeable? (Not only in power terms, also in bass quality)
    Thanks!
  2. Mitch E S
    Mitch E S Stunt Coordinator
    Apr 6, 2002
    87
    Sandra,
    I'll let you know in a couple of days. I currently have a 16-46CS+ and should be recieving an Ultra tomorrow. I'll be putting the CS+ in a stereo only setup and using the Ultra for HT. I'm planning on running both off the same amp (Crown CE 2000) 660W @ 4 ohms (stereo) or 1950W @ 4ohms bridged. I have run the CS+ off the amp bridged 1950W with no problem. I'm pretty sure you'd hurt yourself before the Ultra. I should have a better idea by Sunday (assuming UPS doesn't screw up[​IMG]
    Mitch
  3. Sandra B.
    Sandra B. Extra
    Aug 19, 2002
    24
    I'll be waiting for that comparision Mitch!
  4. John F. Palacio
    John F. Palacio Supporting Actor
    Jan 6, 2002
    575
